Forums >> Revit Building >> Technical Support >> Rendering : Colored semi-transparent canopy strips
Mon, Jan 26, 2015 at 7:44:35 PM | Rendering : Colored semi-transparent canopy strips
annateo301
Hi,
Just wondering if anyone has ever tried making this work when rendering.
The main roof cladding is metal trapezoidal roofing. However, there are a few strips in the frontal of the building that has the same cladding pattern but different material (ie clear transparent roofing). On the underside of these strips are colored polycarbonate glazing (in replacement for typcial soffit).
I am wanting a render to show light passing thru these colored strips and producing colored beam on the walls and floor. Any idea if Revit could do this?
Tue, Jan 27, 2015 at 6:51:05 AM | Rendering : Colored semi-transparent canopy strips
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You would have to use something like glass with a transparency to it to achieve what you are trying to do.  If they are in panels you could have used sloped glazing
Tue, Jan 27, 2015 at 1:50:43 PM | Rendering : Colored semi-transparent canopy strips
annateo301
I've made the roof material as glass. However, This is how it looked like when I set the graphic option to Realistic. As you can see in the attached image, the light passes thru the semi-transparent strip but it doesnt bring thru any color from the tinted strips. Also, when I render, the image doesnt show the light passes thru the roof.
Tue, Jan 27, 2015 at 3:16:50 PM | Rendering : Colored semi-transparent canopy strips
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Revit won't render colored shadows which is what I believe you are trying to accomplish.
Tue, Jan 27, 2015 at 3:33:36 PM | Rendering : Colored semi-transparent canopy strips
annateo301
Sad
Well, I guess I'll just have to photoshop it then..
Thanks teafoe5!
Tue, Jan 27, 2015 at 4:49:08 PM | Rendering : Colored semi-transparent canopy strips
shenis
Semi-transparent?
Thu, Feb 18, 2010 at 3:23:50 PM
rendering trees as semi-transparent
Thu, Aug 7, 2008 at 9:18:15 AM
Imported SAT models are semi transparent
Mon, Oct 25, 2010 at 7:42:05 AM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
Walkthrough showing semi transparent lines and surfaces!??
Thu, Aug 15, 2013 at 4:28:33 PM
Page generation time: 0.3732
