Forums >> Revit Structure >> Technical Support >> Revit 2012 Window Sweeps
Tue, Jul 31, 2012 at 1:00:33 PM | Revit 2012 Window Sweeps
winterriver
Hope this makes sense.
We currently have our mullions as a detail item family imported into an enlarged callout details. No problem. I can create a sweep for a cornice (e.g.) from an imported profile family>editing the wall assembly modify types sweeps or add it as a sweep to the wall assembly one wall at a time.  Is there a process to edit or create a window that has the mullion as a sweep the same way as a wall assembly so when we cut a section we see the mullion in detail?
Tue, Jul 31, 2012 at 1:07:01 PM | Revit 2012 Window Sweeps
You can always add detail components to families that will show in designated views if that is what you were asking.
You can also add sweeps in a family and control their visibility seperately.
So you could have simple a model sweep for 3D purposes which is turned off in plan and replaced with 2D linework.
Tue, Jul 31, 2012 at 1:13:56 PM | Revit 2012 Window Sweeps
winterriver
Thank you wwhub. I would like to add the mullion into the window family so that when a seciotn was cut through the window the mullion would show in greater detail. I wanted to eliminate the step of importing a detail family into a detail callout view.
Tue, Jul 31, 2012 at 2:09:05 PM | Revit 2012 Window Sweeps
winterriver
please see below. I am trying to make this detail mullion a sweep within the window family
Tue, Jul 31, 2012 at 2:15:40 PM | Revit 2012 Window Sweeps
DON'T do this as a sweep.  There is no need to model spacves you never see like the thickness of that tube.  Instead, model a simple rectanglular sweep for 3D and 2d linework fo plan and or section views.
Tue, Jul 31, 2012 at 2:21:08 PM | Revit 2012 Window Sweeps
winterriver
Thanks
Sweeps and window mouldings
Tue, Jul 31, 2012 at 1:01:54 PM
Using sweeps for window construction
Tue, Jan 17, 2006 at 11:22:26 PM
2012 Wall sweeps exporting problems
Fri, Jun 3, 2011 at 10:48:50 AM
Window Family issue - Revit 2012
Sun, Jun 12, 2011 at 11:12:58 AM
In-Place Family sweeps issue
Tue, May 15, 2007 at 4:56:50 PM
Page generation time: 1.7201
