Forums >> General Discussion >> Revit Project Management >> Could someone send me an Daylighting Analysis image for LEED?
Fri, Sep 23, 2011 at 9:59:01 AM | Could someone send me an Daylighting Analysis image for LEED?
joffutt1
We are getting ready to submit a LEED Daylighting Analysis report and need to compare it to another image to see if readings that others are getting are consistant or not.
If you havn't read my other thread that i posted yesterday, we have been doing lighting simulation using 3DS and seem to be getting numbers that are incosistant.  The numbers closest to the windows are the hightest which is good but towards the back of the room where it is lower there seems to be spikes in the numbers on an average of 50 fc.  Does anyone else have this?  Is this normal?
If someone can attach an image preferably done in plan view that would be great.
Sat, Sep 24, 2011 at 12:37:30 AM | Could someone send me an Daylighting Analysis image for LEED?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
http://therevitguy.carbonmade.com/projects/3037323#7
here is a LEED project i did
Mon, Sep 26, 2011 at 7:08:29 AM | Could someone send me an Daylighting Analysis image for LEED?
joffutt1
Is there anyway i can get a .pdf or a closeup image of G1.20?
That looks very nice.  So it looks like you included it as a sheet in the CD set?
Mon, Sep 26, 2011 at 10:16:43 AM | Could someone send me an Daylighting Analysis image for LEED?
joffutt1
Also,
How did you export the anaylisis pictures from 3ds and get them into Revit in a way that looks readable.  Right now, i am using the windows snipping tool for screen captures in order to get the daylighting images for the LEED submittal.  You've seem to have streamlined the process quite a bit.
Mon, Sep 26, 2011 at 1:24:35 PM | Could someone send me an Daylighting Analysis image for LEED?
alabaster2513
3.5 Stars: 25 Votes
yeah i use jing or something similar for screen captures then clean it up in photoshop then overlay it in as an image in my Revit sheet
Mon, Sep 26, 2011 at 1:29:31 PM | Could someone send me an Daylighting Analysis image for LEED?
joffutt1
would you mind posting a pdf of that sheet?
Mon, Sep 26, 2011 at 4:36:12 PM | Could someone send me an Daylighting Analysis image for LEED?
alabaster2513
3.5 Stars: 25 Votes
i'll have to post it later tonight or tomorrow, I am at an office where I do not have access to my portfolio
Tue, Sep 27, 2011 at 7:05:20 AM | Could someone send me an Daylighting Analysis image for LEED?
joffutt1
sounds good. Thanks.
Appreciate all your help.
Tue, Sep 27, 2011 at 12:54:25 PM | Could someone send me an Daylighting Analysis image for LEED?
alabaster2513
3.5 Stars: 25 Votes
pdf doesnt read very well. it prints much cleaner. i also included the light meter legend as a reference
Edited on: Tue, Sep 27, 2011 at 12:55:50 PM
Tue, Sep 27, 2011 at 1:31:27 PM | Could someone send me an Daylighting Analysis image for LEED?
joffutt1
Thats great! Thanks a lot.
Was this one that you submitted and LEED accepted?  There just doesn't seem like a standardized way to submit these.  Thanks so much.
Btw, i was looking at your readings and yours looks like it goes up and down as well in places.  Looks like its not a problem if Leed accpeted it.  Just wanted to make sure it wasn't just me.
Tue, Sep 27, 2011 at 1:37:28 PM | Could someone send me an Daylighting Analysis image for LEED?
alabaster2513
3.5 Stars: 25 Votes
by the large windows i have sun shades with ivy growing on them and solatubes throughout the building. everywhere you see a circle on the floor that is a placement of a solatube. and yes we submitted this along with data from the manufacturer that reflects a consistancy in the numbers,
Tue, Sep 27, 2011 at 2:10:40 PM | Could someone send me an Daylighting Analysis image for LEED?
joffutt1
Ok.
How did you get your numbers on the light lister to be black.  For some reason, my are all white readings over the psuedo color.
Tue, Sep 27, 2011 at 3:59:43 PM | Could someone send me an Daylighting Analysis image for LEED?
#13
alabaster2513
3.5 Stars: 25 Votes
i change the color in photoshop
Wed, Nov 7, 2012 at 9:40:52 AM | Could someone send me an Daylighting Analysis image for LEED?
#14
JDNewton
Did you do a single analysis for each room and then import/combine them in Photoshop?
I can't figure out a way to get a color analysis with numbers for an entire floor, just single rooms based off of individual camera views.
Thanks,
Wed, Nov 7, 2012 at 11:43:57 AM | Could someone send me an Daylighting Analysis image for LEED?
#15
alabaster2513
3.5 Stars: 25 Votes
i did a light meter for each room. im pretty sure there is a plugin for revit now that does this same thing but i cant remember the name
Daylighting Analysis Help-Revit into 3DS Max
Mon, Sep 26, 2011 at 1:18:53 PM
Model Analysis
Mon, Mar 4, 2013 at 2:10:38 PM
GENERATE ENERGY ANALYSIS
Sat, Nov 11, 2017 at 6:51:18 AM
Load Calcs for LEED
Thu, Apr 17, 2008 at 3:41:03 PM
Finite Element Analysis
Wed, Sep 29, 2010 at 12:17:34 PM
Page generation time: 2.6598
