Forums >> Revit Systems >> Technical Support >> Need assistance building a reducing tee family in MEP 2011
Mon, Aug 16, 2010 at 2:10:56 PM | Need assistance building a reducing tee family in MEP 2011
jfmonod
Hi,
 I am attempting to build a reducing tee welded pipe fitting and am having a little trouble with the existing text file lookup table.
 More to the point, I am starting from the out-of-the-box "Tee Reducing - Threaded - MI - Class 150" and am trying to get this to resemble the fittings shown in the attached PDF. After removing the bands and all associated parameters, I am running into trouble reconciling the "Center to End" parameters with the C and M dimensions shown in the PDF table.
Replacing the values in the CSV file isn't coming close to the sizes given and I don't seem to be unable to edit the following :
text_file_lookup(Lookup Table Name, "CtE1", 0.29 * Nominal Diameter 1 - 0.05 * Nominal Diameter 2 + 0.52 * Nominal Diameter 3 + 0'  0 181/256", (Nominal Diameter 1), (Nominal Diameter 2), (Nominal Diameter 3))
 without ending up with an "invalid number of arguments".
 If anyone can shed some light here I would greatly aprreciated it.
 Thanks
 JF
Wed, Aug 18, 2010 at 11:36:32 AM | Need assistance building a reducing tee family in MEP 2011
jfmonod
Nevermind. I figured it out
Wed, Aug 18, 2010 at 12:07:00 PM | Need assistance building a reducing tee family in MEP 2011
Hey come on jfmonod - share.
We ask everfyone who answers their own question to post the answer so others can benefit.  Sharing information is how this forum works.
So... please post the answer.
Wed, Aug 18, 2010 at 4:33:44 PM | Need assistance building a reducing tee family in MEP 2011
jfmonod
Ok. How to create a Reducing Tee fitting for people who don't know jack about pipes .... (like me)
First off is understanding how Lookup Tables work. My problem was twofold:
1. I was trying to reverse engineer an existing fitting and modify it. Lookup tables don't deal with this very well apparently. I added a couple of parameter fields to the csv file and rebooted revit and the result was an "Invalid Formula" or similar error every time I tried to implement these fields in the Family Types panel. It drove me mad.
 So I rebuilt the geometry from scratch with a fresh set of parameters and a new Lookup Table built from the data on the Taylor Forge welded fittings sheet I attached to this post.  The following blog post and the accompanying Whitepaper were very helpful   http://inside-the-system.typepad.com/my_weblog/2008/11/revit-mep-text_file_lookup-and-lookup-tables.html
2. I was having difficulty in defining the "Not in the Table" parameter (in the example in my question that's    0.29 * Nominal Diameter 1 - 0.05 * Nominal Diameter 2 + 0.52 * Nominal Diameter 3 + 0'  0 181/256" )
 I haven't got a clue where that formula came from in the original fitting, but I substituted it in each case by plotting a graph of the relevant dimensions of each fitting size in Advanced Grapher (http://www.alentum.com/agrapher/) and extracting a likely linear formula  with regression analysis. PDC is good enough for me.
 The end result is the family which I am attaching now to this reply. Not all sizes are included in the csv file. We only needed 2" - 12" and I am told that nobody uses 3.5". Anyway any comments, improvements etc... are welcome. I will be following up with an eccentric reducer and a concentric reducer from the same manufacturer (same pdf sheet).
 JF
oval to round tee fitting family
Thu, Jan 13, 2011 at 4:25:41 PM
pipe tee size
Thu, Jun 7, 2018 at 3:50:08 PM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
Red tee
Thu, Dec 30, 2010 at 12:09:29 PM
NEED HELP WITH AN MEP FAMILY, NEW TO THIS, I HAVE TWO QUESTIONS.
Mon, Nov 16, 2009 at 7:10:01 PM
Page generation time: 1.1291
