Forums >> Revit Building >> Technical Support >> Life Safety Wall Rating Pattern
Fri, Dec 12, 2008 at 12:33:03 PM | Life Safety Wall Rating Pattern
rdekarske
rdekarske Avatar
How would I go about creating a revit pattern with the text in it.  I'm still trying to resolve an issue with an AHJ.  I think I've figured out a way to create a wall that shows the following Life Safety Wall Ratings.
--4S--4S--4S   =  4 hour smoke separation
-X1-X1-X1-X1    =  1 hour fire separation
-XX2-XX2-XX2-XX2    =   2 hour fire separation
--OS--OS--OS  =  Smoke Compartment
--1S--1S--1S    =   1 hour smoke separation
--2S--2S--2S    =  2 hour smoke separation
I just need to know how to create a revit pattern for each of the ratings.
Any ideas?   Tutorials?
Thanks in advance !
Rick De Karske
Rick De Karske
"Welcome to the human race... where even the winners don't get out alive !"
Fri, Dec 12, 2008 at 12:59:33 PM | Life Safety Wall Rating Pattern
tim123
4 Stars: 19 Votes
When you talk about a pattern do you mean a linetype?  If so check this blog.
http://revitfamilies.blogspot.com/search?updated-min=2007-01-01T00%3A00%3A00%2B02%3A00&updated-max=2008-01-01T00%3A00%3A00%2B02%3A00&max-results=16
Alternatively you could use different hatch patterns or colours for the different types of walls with a key.
Fri, Dec 12, 2008 at 1:11:13 PM | Life Safety Wall Rating Pattern
rdekarske
rdekarske Avatar
HI Tim,
Thanks for the reply but colors won't be accepted by the State Inspector.  In AutoCAD Architecture it's possible to make a wall with the text in the middle of it.  I think I've figured out a way to do that in Revit.  The stud would carry the pattern with the text as I showed in my orginal post.  I just need to find out how to turn that text into a pattern.
Rick
Rick De Karske
Fri, Dec 12, 2008 at 2:35:19 PM | Life Safety Wall Rating Pattern
tim123
4 Stars: 19 Votes
I don't think that it's possible to do it in the wall, but you can create it with a repeating detail where you just need to click the wall and it can be applied.
Fri, Dec 12, 2008 at 2:59:45 PM | Life Safety Wall Rating Pattern
rdekarske
rdekarske Avatar
Hi Tim,
 Thanks again for responding.  I'll try that.  I just pulled up the tutorial to do that.
Rick
Rick De Karske
Wed, Jan 21, 2009 at 11:11:13 AM | Life Safety Wall Rating Pattern
JFLYNN
Use AutoCad to create a detail, in this case type -1-
get the detail into Revit and use it to create a REPEATING DETAIL in your drafting view. With a little effort and patience and a rotaion and small adjustments you will have your "linetype".
I also did this to create a fence "linetype" in plan, you know, the traditional --X--X--X--X--X
Wed, Jan 21, 2009 at 11:25:17 AM | Life Safety Wall Rating Pattern
rdekarske
rdekarske Avatar
J Flynn,
 Thanks... That sounds really easy to do.  I'm pretty new to this REVIT stuff and definitely still learning.
Rick
Rick De Karske
Wed, Jan 21, 2009 at 11:28:28 AM | Life Safety Wall Rating Pattern
Why do this in CAD ????
If you want a repeating detail, do it with a REVIT Detail family   NOT CAD!   Fake your numbers with linework.
Wed, Jan 21, 2009 at 11:39:08 AM | Life Safety Wall Rating Pattern
JFLYNN
Well, you can create the subcomponents however you feel comfortable, then get them into a repeating detail.
Scan an etch a sketch if you want. Then get the detail into Revit Smile Then make a repeating detail.
I personally don't get paid to draw numbers when there are 4.6 million fonts already in existance... drawing the number "one" feels foolish to me...
Wed, Jan 21, 2009 at 11:52:32 AM | Life Safety Wall Rating Pattern
tim123
4 Stars: 19 Votes
WWHub is correct why do it in cad when it is easier than revit.  Look at the blog - it solves the problem perfectly.  You don't need to draw the number.  You can create a parameter to insert any letter or string and you can have any font that you want.
Wed, Jan 21, 2009 at 11:53:44 AM | Life Safety Wall Rating Pattern
#11
tim123
4 Stars: 19 Votes
Sorry - I meant that it is easier in Revit.
Wed, Jan 21, 2009 at 12:59:05 PM | Life Safety Wall Rating Pattern
#12
KingRevit
4 Stars: 12 Votes
hi it is possible to do what you want in revit.
i will load up everything you need to do it.
I all so have a video that shows exactly how to do this. if someone can give me access to a site where i can upload it i will as i have been onto revit city before about being able to upload videos before and we still don't have the ability.
the file is 4 mins long and 162mb
Wed, Jan 21, 2009 at 1:27:02 PM | Life Safety Wall Rating Pattern
#13
4 Stars: 205 Votes
Hi KING, glad to see you man, put the video in Megaupload if you want and put the link here...
Thu, Jan 22, 2009 at 10:17:09 AM | Life Safety Wall Rating Pattern
#14
KingRevit
4 Stars: 12 Votes
video is here
http://www.megaupload.com/?d=QJIHRSDO
Tue, Jun 28, 2011 at 6:00:41 PM | Life Safety Wall Rating Pattern
#15
TTSchiller
Is it possible to put the video on YouTube or something? It's a pretty big file to download.
Life Safety Paths
Fri, Oct 4, 2019 at 4:35:29 PM
Detailed Life Safety Symbols
Mon, Jan 3, 2022 at 2:48:32 PM
Life Safety Plans
Thu, May 22, 2014 at 9:16:09 AM
Life Safety Plan Travel Distances?
Tue, Apr 24, 2007 at 2:29:47 PM
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Page generation time: 0.7247
