Forums >> Revit Building >> Technical Support >> Area Tags
Tue, Jan 22, 2008 at 1:58:54 PM | Area Tags
Dragonfollower
Hello, I use revit 2008 at work and I was wondering, although I am fairly certain of the answer, whether anyone has managed to place an area tag on a floor plan. I understand you need to set up the area plans and all that but to have the tag on the origional floor plans after you set up the area plan. I'm guessing I'm going to get a lot of no's but I thought I would ask.
Tue, Jan 22, 2008 at 2:00:35 PM | Area Tags
Dragonfollower
Sorry I should also add that I dont want the room areas. I am working on a condo and I need the suite areas which I set up on the area plan.
incompatible area tags
Sat, Jan 14, 2006 at 1:57:46 AM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
Area Tags
Thu, Jul 29, 2010 at 12:43:26 PM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
Link suite tags to area plan tags?
Mon, Sep 22, 2008 at 7:18:12 AM
Page generation time: 2.5189
