28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Exterior Bearing Walls?
1 Posts No Rating |
Is there a way to classify exterior walls as load bearing? I am trying to show portions of the exterior wall as bearing walls for my structural plans. I cannot find the location to change this setting. I found the setting for the interior walls. Thanks
The place to find the setting should be the same as for the interior walls. Right click on the wall, select "Element Properties", scroll down to the structural catagory and select bearing. Good luck.
Bearing vs. Non-bearing walls |
Wed, Oct 10, 2012 at 3:04:30 PM
Before I Start Copy/Monitor |
Thu, Sep 6, 2012 at 10:19:47 AM
exterior finsh below zero |
Sun, Apr 11, 2010 at 10:13:36 AM
Plan region/bearing walls |
Mon, Jan 21, 2008 at 12:14:19 AM
Floor Truss Endpoint on Bearing Wall |
Thu, Jan 16, 2014 at 9:52:23 AM
