Forums >> Revit Building >> Technical Support >> Can't add shared parameter to material tag?
Mon, Jan 21, 2008 at 5:58:33 PM | Can't add shared parameter to material tag?
ksymons
Hello,
I am trying to coordinate our standard AutoCAD tags into Revit 2008.  I have not run into any trouble using shared parameters when I duplicated our wall type tags but now I am having trouble with my material tag.  I'm trying to add a shared paramter called "Finish Tag" and I went through the process- making the label and adding then selecting the shared paramter which showed up on the list just fine.  But after I click on OK and go back to the list, it no longer appears there.  Is this some kind of error/bug with material tags?  Because I repeated the process after changing family parameters to floor tag or wall tag and it worked just fine.
The only workaround I can think of right now is make the same material tag symbol but categorize it as wall, floor, etc tag instead of material tag so I can get my shared parameter to appear properly.  Should I continue down that path?  Or is there a solution to the material tag error?
Thanks in advance,
KS
EDIT- Sorry, the attached file has it categorize has a Floor tag at the moment (which works the way I want it to), so please change it to Material tag in order to see where I am coming from.
Edited on: Mon, Jan 21, 2008 at 6:00:11 PM
Shared Material Between Families
Mon, Aug 31, 2015 at 11:21:40 AM
Family type name as shared parameter?
Mon, Oct 10, 2011 at 8:28:04 AM
URL parameter in a room tag
Thu, Feb 18, 2010 at 3:55:55 AM
Using a Yes/No Parameter to control the visibility of another Label in a Tag
Wed, Feb 6, 2013 at 2:03:21 PM
Material Description to be scheduled
Fri, Sep 19, 2014 at 9:18:12 AM
Page generation time: 1.0045
