27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Column Grid Line Weight
14 Posts No Rating |
I'm currently working on a parking garage in Revit Architecture 2008 and I have come to a issue that I can't solve! I'm adding column grid and I want to adjust the line weight of the grid itself. I have adjusted the head of the column grid to be a 4, but I have no selection in the "Visibility Graphics>Object Styles" to adjust the line weight of the grid. Any help? Thanks!
Mine might be set up differently than yours, but I can change that line-weight by clicking on a grid line, hitting properties, clicking Edit/New... and changing the Line Weight parameter in the family type parameters. Hope that helps.
That worked! Thanks... Don't you think that all the line weight controls should be this way?
Hi
Is it possible to change Grid Head circle thickness?
so that the grid line will be lighter and the bubble circle will be a bit darker
yeah, sorry, i got it
it is from Manage, Annotation , Grid head line thickness
Column Grid line missing when printing |
Mon, Nov 23, 2009 at 11:20:50 AM
Column to Grid |
Tue, Sep 8, 2009 at 4:09:31 PM
Ceiling grid line weight |
Wed, Aug 8, 2018 at 4:33:13 PM
Column Grid Text |
Tue, Dec 11, 2007 at 9:33:36 AM
column grid visibility |
Wed, Nov 15, 2006 at 3:43:13 PM
