Forums >> Revit Building >> Technical Support >> hatch pattern modification???
Mon, Jan 21, 2008 at 9:21:40 AM | hatch pattern modification???
skibum71
3 Stars: 1 Votes
morning, all...  seems this should be very simple to do, but i can't figure out how to...  i want to create a model hatch pattern (revit arch 0Shadey for 8x24 cmu.  i wm trying to use 8x16 cmu as base, and copy/modify, but it doesn't seem to give any options for this...  any ideas???  thanks in advance!
 i see that hatchkit website, but it says that the free version creates watermarks on the hatches, which i can't have on construction issue dwgs...
Mon, Jan 21, 2008 at 11:16:00 AM | hatch pattern modification???
Hatches are just text files which you can edit. Type this in a simple txt file with notepad and this should work. (the 12 replaced the normal 8 for a 8x16)
*CMU_8x24 Running, CMU: 8x24 Running bond
0,   0,0,   0,89
0,   0,0,   8,12,   8,-8
Edited on: Mon, Jan 21, 2008 at 11:16:50 AM
Edited on: Mon, Jan 21, 2008 at 11:17:20 AM
Tue, Jan 22, 2008 at 10:44:29 AM | hatch pattern modification???
skibum71
3 Stars: 1 Votes
wwhub...  that did it!  rock o!  thanks for the help, i appreciate it.
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:07 PM
custom hatch pattern without hatch editor
Wed, Jan 28, 2015 at 8:46:58 PM
Page generation time: 3.3031
