25 Users Online (23 Members):
Forums >> General Discussion >> Revit Project Management >> Keynote Scheduling
5 Posts No Rating |
I have scheduling problems with my keynotes. . . I have (3) seperate keynote families, and I cant seem to get my schedules to report them in seperate schedules. I have; Floor Plan Keynotes, Elevation Keynotes, and Section Keynotes. I want to have (3) seperate keynote schedules on seperat pages reporting the appropriate keynote family I have set up. . . Please help! Oh yeah I'm still working on Revit 8.1.
----------------------------------- JDR |
Good day John, Are you at all familiar with filtering the keynote schedules? Or have you already tried this and it's not working?
5 Posts No Rating |
THE FILTERING BOX ONLY BRINGS UP KEYNOTE NUMBER & DESCRIPTION. IF IT LET ME FILTER BY FAMILY IT WOULD BE PERFECT AS THEY ARE DIFFERENT FAMILIES.
Put something in the description. Then us it in a filter. call one keynote 'keynotea' and then use the filter to only show keynotes that have 'keynotea' in the description field. There are probably other ways to do this too.
At the bottom of the filter box is a box that say's "Filter by sheet". Check this box and it will only schedule the keynotes you have on that particular sheet. I think that's what you were looking for. Good luck.
5 Posts No Rating |
I TRIED TO PUT A FILTER IN THE DESCRIPTION, THEN EVERYTHING DISAPPEARED! I WORKED IT AROUND FOR A WHILE BUT COULDNT GET IT TO SHOW U RIGHT. I EVEN TRIED TO PUT A FILTER IN THE NUMBER FIELD IE; S1 S2 S3 ETC. THEN I FILTERED IT BY NUMBER THAT CONTAINS S AND EVEN TRIED S1 SPECIFICALLY. NO WORKY WORKY AAAHHHH I DONT HAVE THAT CHECK BOX THAT FILTERS BY SHEET IS THAT IN A NEWER VERSION OF REVIT THATN 8.1?? THANKS SO MUCH FOR THE HELP... PLEASE KEEP EM COMIN ITS NOT WORKING YET! IVE JUST CREATED THE SCHEDULE WITH TEXT, BUT I WANT TO MAKE IT WORK RIGHT.
Do you have your filter set opposite to what you really want? try switching the contains/does not contain field. This is the first thing that pops into my head.
5 Posts No Rating |
UM MY FILTER GOES AS FOLLOWS; FILTER BY;DESCRIPTION, CONTAINS, S. THEN THE SECTION KEYNOTES ALL DISSAPPEARED OFF THE PAGE CORRECTLY, THEN I PUT S AS A DESCRIPTIONFOR ONE OF THE KEYNOTES, I EXPECTED TO SEE THE 'S' DESCPTION TO SHOW UP IN THE SCHEDULE BUT IT DIDN'T. ANY THOUGHTS
keynote categories |
Fri, Aug 10, 2012 at 3:56:23 PM
Multiline keynote |
Thu, Jan 8, 2009 at 2:31:33 PM
Keynote Legend Not Showing Keynote Text |
Fri, Sep 6, 2013 at 11:40:59 AM
12
Keynote Text in Schedules |
Thu, Sep 11, 2014 at 4:45:04 PM
Keynote Data problem |
Wed, Feb 2, 2011 at 2:35:58 PM
