Forums >> Revit Building >> Technical Support >> Got a problem with texture orienting from a imported revit model in 3DS MAX 2008
Sat, Jan 19, 2008 at 4:15:07 PM | Got a problem with texture orienting from a imported revit model in 3DS MAX 2008
Ballrog
Hi
Im using Revit Architecture 2008, and 3ds max 2008, and ive got a problem when i try to put a roof texture on my imported house model. The problem is that the roof-texture doesnt align with each individual face of the roof, as it does in Revit. Instead the roof tiles are alltogether oriented in one direction, so at one face of the roof the tiling orientation is correct, but on the corresponding side it is not. Its probably because the texture coordinates arent based on the individual faces on the roof, but on the entire roof model. Im sorry if im clumys in the way i describe this in english, so i attach a picture to show what the problem is about.
 I would appreciate if aomeone can tell me how to get past this issue.
Tue, Mar 31, 2009 at 10:15:40 AM | Got a problem with texture orienting from a imported revit model in 3DS MAX 2008
Berryjiveuptown5
I know it's kind of an old post, but check this guy's tutorials on importing a Revit model into 3ds.  You have to apply a modifier in order to fix the texture.
I would have suggested asking this question in a 3ds forum.
The mehtod @3:25 solves your problem:
http://www.youtube.com/watch?v=Hi8L-2vQ8vc&feature=channel
REVIT and 3ds MAX
Mon, Apr 4, 2005 at 4:45:15 PM
exporing revit 09 to 3ds max with lights???
Tue, Jun 2, 2009 at 5:53:27 AM
problems with Revit 2013 in 3ds Max!
Fri, Dec 14, 2012 at 4:25:44 PM
13
RPC's won't render in 3DS Max after importing from Revit
Sat, Dec 17, 2005 at 9:10:50 AM
Revit that contains linked revit files - linked to 3ds max design fails
Mon, Feb 24, 2014 at 4:59:33 PM
Page generation time: 2.2486
