11 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Looking For Easy Way to Control Lineweights When Linking DWG Files
16 Posts No Rating |
I want to maintain a library of AutoCAD 2008 2d typical details and link them into drafting views in Revit Struct 2008. DWG files are drawn with lineweights by color and all linework is drawn with color "bylayer". I haven't had luck in Revit using the File>Import/Export Settings>Import Lineweights DWG/DXF as all linework imports to a single line thickness. As I repeatedly import many files, how do I control lineweights in Revit without teadiously changing the lineweights of each layer in each imported file? Using Visibility/Graphics Overrides for every imported file is very slow.
Whoops. I am wrong. File>Import/Export Settings>Import Lineweights DWG/DXF does control lineweights. Make changes to settings prior to loading links.
Problems linking DWG CAD files into Revit |
Wed, May 14, 2014 at 10:33:52 AM
line weights problems corresponding to ACAD ref files |
Tue, May 4, 2010 at 8:37:29 AM
linking dwg files in elevations |
Wed, Nov 23, 2005 at 3:04:32 PM
DWG linking into revit |
Mon, Jun 9, 2014 at 7:11:38 AM
Managing big linked files and exporting to 3ds max |
Tue, May 11, 2010 at 8:06:15 PM
