Forums >> Revit Structure >> Technical Support >> NON-PRINTING LAYERS??
Thu, Jan 17, 2008 at 9:14:04 AM | NON-PRINTING LAYERS??
ZBro
I want to be able to put information (text mainly) on my drawnigs that I can see on my screen but do not print.  This is useful to show loads and in-house comments/reminders.  I understand that "hide in view" is a method to do this but the downfall is you have to remember to hide everything before you print and remember to look at hidden items when you are working ... both cumbersome.  Is there a way to filter a linetype or create non-printing linetypes?
Thanks in advance for your tips!
Thu, Jan 17, 2008 at 10:11:32 AM | NON-PRINTING LAYERS??
NKramer
4 Stars: 9 Votes
Your only options are either the default <Invisible Lines> line type or to create a line type that plots as white. both of these are only visible if you hover over them, which doesnt work to well for in house notes. The only other thing that I have done is create "Drafter's Notes" on our default template that says do such and such at project start up and then delete this note.
I got overly use to useing the non plot layers in Autocad, but as far as I am aware these are the only ways to replicate something along those lines.
HTH
Nick
Thu, Jan 17, 2008 at 4:40:34 PM | NON-PRINTING LAYERS??
Westview
2.5 Stars: 2 Votes
You could try to duplicate the view and put all your notes on the duplicate view and plot the original view.
Thu, Jan 17, 2008 at 4:58:33 PM | NON-PRINTING LAYERS??
ZBro
good tip, thanks
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
Changes to AutoCAD layers when imported to Revit
Wed, Oct 29, 2008 at 10:35:39 AM
Imported layers still active when exporting
Fri, Feb 26, 2010 at 8:44:40 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:15 AM
17
Seperating layers hatch with filter
Wed, Feb 12, 2014 at 3:15:30 AM
Page generation time: 0.0938
