Forums >> Revit Building >> Technical Support >> I need a simple hatch pattern for a waffle ceiling
Wed, Jan 16, 2008 at 6:01:13 PM | I need a simple hatch pattern for a waffle ceiling
Caliber
I am making a waffle ceiling and I'm trying to create a reflected ceiling plan.
all I want is a hatch pattern  2' 6" square thats spaced 6" apart.
Can anyone give me that hatch pattern or tell me an easy way to make it
 I posted an example picture of how the fill pattern should be. PLEASE HELP!
Wed, Jan 16, 2008 at 7:47:34 PM | I need a simple hatch pattern for a waffle ceiling
hugh
3.5 Stars: 4 Votes
Try this
 ;%VERSION=3.0;%UNITS=INCH*WAFFLECEILING,30" waffle @ 36" pitch both ways;%TYPE=MODEL;-------------------------------------------------------------------------------;        Pattern written by HatchKit v2.7 Hatch Pattern Editor;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2007.;        www.cadro.com.au/hatchkit/;-------------------------------------------------------------------------------;-Template=NEW,;-Date    =17/01/2008;-Time    =12:51:56 PM;-HatchKitVersion=2.7.1.1980;--------------------------------------------------------------------------------90,0,30,0,36,30,-6180,30,30,0,36,30,-690,30,0,0,36,30,-60,0,0,0,36,30,-6
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
Wed, Jan 16, 2008 at 7:54:17 PM | I need a simple hatch pattern for a waffle ceiling
hugh
3.5 Stars: 4 Votes
Hmm, that would have been better if I had attached the file instead. Fixed.
Hugh
Thu, Jan 17, 2008 at 9:46:27 AM | I need a simple hatch pattern for a waffle ceiling
Caliber
Thank you Very much that solves hours of research.
Fri, Jan 18, 2008 at 12:53:44 AM | I need a simple hatch pattern for a waffle ceiling
hugh
3.5 Stars: 4 Votes
No worries, it is a very simple pattern.
Draw a 30" square and space 6" apart.
Save as a Revit model pattern.
Hugh Adamson
www.hatchkit.com.au
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:42 AM
14
ceiling hatch pattern
Thu, Apr 17, 2014 at 6:59:10 AM
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
invisible ceiling pattern
Mon, Oct 17, 2011 at 7:20:11 AM
Vertical Hatch Pattern
Wed, Feb 17, 2016 at 1:56:36 PM
11
Page generation time: 2.8511
