Forums >> Revit Building >> Technical Support >> halftone hatch/fill pattern?
Wed, Jan 16, 2008 at 9:22:25 AM | halftone hatch/fill pattern?
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
Is there any way to make a hatch/fill pattern halftone?
Wed, Jan 16, 2008 at 9:24:53 AM | halftone hatch/fill pattern?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I achieved this by simply turning the fill pattern to Gray color and using Raster style printing. The printer recognized the gray color as halftone and printed accordingly. I am not sure of any other way to do this.
Wed, Jan 16, 2008 at 9:27:38 AM | halftone hatch/fill pattern?
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
Where can I control the color of the hatch if I do it that way?
Wed, Jan 16, 2008 at 9:40:26 AM | halftone hatch/fill pattern?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Edit the filled region and click on Region Properties on the left pane. Go to Edit/Duplicate and you will see a color parameter. Click on the button and select the gray color.
Wed, Jan 16, 2008 at 9:51:23 AM | halftone hatch/fill pattern?
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
thanks, i guess that will have to work for now!
Wed, Jan 16, 2008 at 10:00:46 AM | halftone hatch/fill pattern?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I just thought of another way to halftone a region. Right click on the region and select Override Graphics in View-->By Element. In the next dialog box you can checkmark the "Halftone" box and it will grayscale it. You can do this for any element in RAC2008
Wed, Jan 16, 2008 at 10:14:12 AM | halftone hatch/fill pattern?
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
I'm actually doing this to a brick hatch pattern on a wall.  The grayscale option works because I only want the hatch pattern halftoned, but if I use the override graphics option then the whole wall becomes halftone which is unacceptable.  Thanks for the help.
Cut/Fill areas with different hatch pattern
Fri, Dec 18, 2009 at 11:21:44 AM
Lost Solid Fill Pattern
Wed, Apr 9, 2008 at 7:58:47 AM
Fill Pattern/Hatch Pattern are not coherent in different views
Thu, Feb 16, 2012 at 7:20:52 AM
Hatch with gradient soid fill? or alternative ways to pattern this
Mon, Dec 17, 2007 at 12:01:22 PM
Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:31 PM
Page generation time: 0.7463
