Forums >> Revit Building >> Technical Support >> Sheets exported to DWG
Tue, Jan 15, 2008 at 5:37:11 PM | Sheets exported to DWG
BrettoAus
I think i am missing somthing when it comes to exporting sheets to DWG format, im using 2008 and when i export to DWG the drawing sheet (eg floor plan) is exported in two parts - the titleblock and the view are exported seperatly. Is the something im doing wrong i wont both the view and of course the title block in the same file.
Any ideas or help would be appriciated. Also i have done a search and cant seem to find anything stating my problem.
thanks
Brett
Brett
Tue, Jan 15, 2008 at 5:42:15 PM | Sheets exported to DWG
BrettoAus
ok, i didnt click on the export as one file.... problem solved.
Brett
Exporting sheets to dwg with shared coordinates
Tue, May 6, 2008 at 9:50:37 PM
Exporting Sheets and sheets only to DWG
Tue, Mar 27, 2007 at 9:42:22 AM
DWG sheets to RVT
Sun, Jun 9, 2019 at 10:57:52 PM
Revit 2012 Export To DWG. Titleblock exported as Block.
Wed, Jun 12, 2013 at 6:16:23 PM
Sheets on DWG exoprts
Wed, Mar 20, 2013 at 7:36:01 AM
Page generation time: 1.5383
