Forums >> Revit Building >> Technical Support >> Annotating Views
Tue, Jan 15, 2008 at 12:59:38 PM | Annotating Views
RWREVITSD
Hey everyone,
Once again I need your services.  I am trying to figure out how to annotate my plans ie: (floor plan notes, site plan notes....etc.), I would like to be able to insert a note in the plan and then have a legend calling out the respective notes.  Please if you know how to do this, or you have any suggestions it would be much appreciated.
RW
Tue, Jan 15, 2008 at 2:56:13 PM | Annotating Views
Read your REVIT help under keynote.
Tue, Jan 15, 2008 at 3:11:49 PM | Annotating Views
RWREVITSD
thank you! I really appreciate it Smile
Tue, Jan 15, 2008 at 3:19:36 PM | Annotating Views
ArchWestCY
4.5 Stars: 7 Votes
I use Note Blocks.  You can get one from the Annotation Folder.  I have made several with circles, squares, and diamonds so that I can have several different Note Blocks (ie. System Notes, Keynotes, Bath Notes) in a single model.  I prefer Note Blocks because you can edit the text inside Revit.  It is as easy as editing any other type parameter.  You can find more info on Note Blocks in the (F1) Revit help files.
 Hope this helps.
ArchWestCY
Annotating displaced elements
Fri, Nov 22, 2013 at 1:38:20 AM
Annotating linked files
Tue, Nov 20, 2007 at 11:42:39 AM
Making annotating elements faster?
Tue, Oct 6, 2015 at 7:41:44 AM
Drafting a model based detail
Thu, Mar 25, 2010 at 9:35:13 AM
Revit building in ACA 2009 project manager
Mon, Dec 15, 2008 at 9:08:31 AM
Page generation time: 0.2780
