Forums >> Revit Building >> Technical Support >> Stairs - viewing from floor above.
Tue, Jan 15, 2008 at 8:12:27 AM | Stairs - viewing from floor above.
gatorkid
I have a two level building, I have created a stair going from level on to level two.  Then I edited the second floor slab to include a hole for the stair to come through and be visible on the second floor plan.  However, I can't see the stair on the second floor plan.  I have checked in section and elevation and the stair is in the right place and located right underneath the hole in the second floor slab.
How can I get the stair to show up on the seond floor plan?  I am using Revit Architecture 2008.
Edited on: Tue, Jan 15, 2008 at 8:13:50 AM
Tue, Jan 15, 2008 at 10:28:24 AM | Stairs - viewing from floor above.
Check the view depth of your view.  If you don't want to change that to the floor below, you can use a plan region with the view depth set correctly.
Wed, Jan 16, 2008 at 11:26:18 AM | Stairs - viewing from floor above.
kesflower
3.5 Stars: 11 Votes
Also check your Visibility/Graphics settings to make sure that stairs are visible in your plan.
Ruth Rau
Main Street Architecture, P.C.
Revit's collor fill hides floor slab floor slab doesnt hide stairs anymore
Thu, Feb 8, 2007 at 2:08:28 PM
Floor Plan View Range - Viewing a half storey
Thu, Jul 12, 2007 at 3:32:23 PM
Stairs to second floor showing full stair
Thu, Jun 4, 2015 at 9:44:02 AM
12
3D Transparent Viewing
Mon, Jun 9, 2008 at 5:45:00 PM
2 sets of stairs, 1 landing, 1 cutback. possible?
Sun, Mar 1, 2009 at 3:28:10 AM
Page generation time: 0.3707
