Forums >> Revit Structure >> Technical Support >> Structural Foundation Tag with Elevation
Mon, Jan 14, 2008 at 4:21:29 PM | Structural Foundation Tag with Elevation
strucdesigner
How can I get the Structural Foundation Tag with Elevation to display top of footing elevation instead of bottom?
Tue, Jan 15, 2008 at 9:13:36 AM | Structural Foundation Tag with Elevation
TyMad
I've been told the only way to get the top of footing elevation is to use a spot dimension. Autodesk did not make a top of footing tag. If you go through the AUGI forums some people have posted work arounds to get it but mostly they just manually put in the top of footing in like the comments category or something in each individual item. I think the spot dimension is the easiest way.
Tue, Mar 20, 2012 at 12:05:31 PM | Structural Foundation Tag with Elevation
pgalla
See Attached.
  1. Set Start Level and end Level Offset to depth of Grade BM.
  2. Set Z justification to other
  3. Set Z Direction offset to where you want the bottom to be.
  4. And that is it.
foundation wall tag
Wed, Jul 22, 2015 at 1:22:24 PM
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
Foundation walls in elevation
Sun, May 22, 2005 at 8:46:49 PM
Can not create structural foundation schedule
Wed, Jul 2, 2014 at 10:36:46 AM
Isolated Foundation atching to column base: Revit 2010
Thu, Jun 25, 2009 at 1:59:29 AM
Page generation time: 2.4285
