9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> stairs up arrow
83 Posts No Rating |
My stairs are not showing the up arrow. checking or not in the stair instance properties has no effect.
Does anybody experienced the same issue? What am I missing?
Thanks.
Yeah the old up arrow's on stairs have always been a bit buggy...
The tend to only work correctly when you've using the run command to draw the sketch. For anything custom you'd be best off drawing the arrow in afterwards or using a detail component arrow.
Hopefully in the next release!
HTH.
Thanks Mr Spot, I guess for consistency I will probably have to redraw my stairs (!).
A little warning from revit about this issue while executing the stair command would have been nice...
six years later..... i think i'm encountering the same problem with Revit 2011. is there, at this time, a better remedy than an annotated arrow?
stairs |
Thu, Nov 29, 2007 at 10:59:31 AM
stair UP / DN arrow |
Tue, Jun 19, 2012 at 6:54:20 PM
Stair Arrow visible only in one view? |
Thu, Oct 11, 2012 at 2:19:25 PM
Stair Issue |
Mon, May 11, 2009 at 1:22:10 PM
Stairs going in the wrong direction |
Sun, Feb 15, 2009 at 5:41:35 PM
