Forums >> Revit Building >> Technical Support >> Solid filled region not printing with hidden line graphics style
Mon, Jan 14, 2008 at 12:46:52 PM | Solid filled region not printing with hidden line graphics style
mmwcolin
I have come across a problem with my solid filled regions not printing in Revit Architecture 2008.  The weird this is that the solid hatches do show up on the screen but under Print Preview or when printed they no do not.  I narrowed down the problem to find that it only happens when the Graphics Style is set to Hidden Line.  I can fix it if I change the setting to Wireframe, but then that messes up other areas of my plan.  This bug doesn't show up if the hatch is not solid, so my current workaround is to change all my solid filled regions to hatches that have densely spaced lines.
 Has anyone else run into this problem before?  I'd love to know if there is a real solution...
Tue, May 13, 2008 at 12:09:02 PM | Solid filled region not printing with hidden line graphics style
jmqrsq
5 Stars: 3 Votes
Any luck with this? we are seeing the same issue. Any help would be appreciated
Tue, May 13, 2008 at 12:13:21 PM | Solid filled region not printing with hidden line graphics style
jmqrsq
5 Stars: 3 Votes
http://revitcity.com/forums.php?action=viewthread&thread_id=7979
check this thread. raster instead of vector \(faster) printing has fixed the issue in our hidden line graphic style annotations. any updates to this would be appreicated.
Chaning the ouline line style for filled regions
Thu, Jul 19, 2007 at 6:31:48 PM
Printing vector changes solid to hidden line, shaded areas don't show correctly
Mon, Apr 20, 2015 at 10:56:21 AM
Showing Center Lines on Hidden Line graphics style
Mon, Oct 13, 2008 at 10:46:14 AM
printing masses with hidden line removal so they are solid
Fri, Nov 16, 2007 at 2:14:43 PM
fill pattern and line style
Thu, May 5, 2005 at 6:25:07 PM
Page generation time: 1.1799
