Forums >> Revit Building >> Technical Support >> Wall sweeps wrapping at ends?
Mon, Jan 14, 2008 at 12:41:55 PM | Wall sweeps wrapping at ends?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
How do I get my 1x6 baseboard to wrap at the end of the wall.  You'll see what I'm talkign about in the image.  Thanks,
Lorne
Denver, CO
Revit Architecture
Tue, Jan 15, 2008 at 9:44:52 PM | Wall sweeps wrapping at ends?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You should be able to select the sweep and click "Change Sweep Returns" in the options bar. You can set this to 90 degrees and then select the blue control dot and pull it to the other side of the wall. This method is a bit tedious, but it works for me. I personally don't like to include sweeps in my wall types because it makes it hard to control visibility and scheduling of those sweeps so i use hosted sweeps for all of my baseboard and chair rails. You can use the blue grips to control the return and length of these sweeps.
Wed, Jan 16, 2008 at 11:15:23 AM | Wall sweeps wrapping at ends?
kesflower
3.5 Stars: 11 Votes
I also use hosted sweeps for baseboard, crown mold, chair rail, etc. To do it that way, you create a new wall type and include the sweep in the wall. Labeling all of the variations can be tricky, and it really works best when all of your walls are going to be the same height, but if you can keep it all straight, I think this way performs faster than applying sweeps to each wall.
Edited on: Wed, Jan 16, 2008 at 11:15:37 AM
Ruth Rau
Main Street Architecture, P.C.
Thu, Jan 15, 2015 at 10:14:14 AM | Wall sweeps wrapping at ends?
Kpinakidis
I have created the wainscotting by using the sweep and editting the type to 3" like drock1627 had explained.
Now I am having trouble getting the sweeps to snap together in the corners making the 45 degree corner. Does anyone know a tool i can use to make the horizontal and verticle wall sweeps snap together in the 4 corners to make essentially a rectangle or square?
Kristina
Thu, Jan 15, 2015 at 10:20:42 AM | Wall sweeps wrapping at ends?
Now you have an image.....
Don't do this as a wall sweep.   Do it as an in-place sweep using the wall face as your work plane.
Thu, Jan 15, 2015 at 11:34:53 AM | Wall sweeps wrapping at ends?
Kpinakidis
Thank you for your advice and picture, I was able to figure it out.
Wrapping sweeps at wall ends & corners? Any suggestions on how to?
Tue, Dec 28, 2004 at 1:08:04 PM
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:02 AM
Wrapping Sweeps for Crown Mould
Fri, Feb 10, 2012 at 4:00:50 PM
DIMENSIONING WALL ENDS
Wed, May 20, 2015 at 8:49:23 AM
wrapping wall materials
Thu, Aug 14, 2008 at 4:40:22 PM
Page generation time: 2.5356
