Forums >> Revit Building >> Technical Support >> Relocating elevation of building
Mon, Jan 14, 2008 at 10:44:15 AM | Relocating elevation of building
tim123
4 Stars: 19 Votes
Is it possible to lower a whole building in relation to the site without individualy changing the levels, which often leads to other problems.  Using the relocate function seems to bring the levels with it - ie they do not change.  Any help here would be appreciated. (Revit 200Shadey.
Mon, Jan 14, 2008 at 12:09:18 PM | Relocating elevation of building
TONYC
TRY THIS
GO TO AN ELEVATION AND CHANGE LEVEL PROPERITIES  FROM A PROJECT- ELEVATION BASE TO A SHARED- ELEVATION BASE.
BUT AFTER YOU HAVE RELOCATE THE PROJECT.
Tue, Jan 15, 2008 at 2:59:13 AM | Relocating elevation of building
tim123
4 Stars: 19 Votes
Thank you - that worked perfectly.
Elevation change of a portion of the building
Wed, Apr 27, 2011 at 10:45:35 AM
Relocating Project
Fri, Jun 4, 2010 at 10:57:27 AM
Building Elevation Scale
Fri, Apr 19, 2013 at 9:24:42 AM
Showing Shadows from a building when the building is behind the elevation line.
Sun, Jul 12, 2009 at 8:02:41 PM
Elevation Shadow Diagrams
Mon, Jun 3, 2013 at 12:02:47 AM
Page generation time: 1.1630
