Forums >> Revit Building >> Technical Support >> Scaling of text, dimensions, and wall textures question.
Mon, Jan 14, 2008 at 10:28:57 AM | Scaling of text, dimensions, and wall textures question.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
RAC 2008
There probably is an easy way to do this that I have overlooked. Can you not set up your text size, dimension scale, cut-texture pattern, etc. and have it adjust automatically when you do a callout, blow up, plan detail, whatever?
For instance, if I want to do a smaller scale plan, say, at half the size of my 1/8" floor plan, I know I can plot it at 50% scale and everything is half size, but if I want to actually use that half size or a double size plan for referencing, etc. in my working drawings, it appears that I have to do a callout and then go in and resize everything to fit.
Any suggestions?
Mon, Jan 14, 2008 at 11:59:03 AM | Scaling of text, dimensions, and wall textures question.
The annotation size you set is the same size no matter what scale the drawing is.  1/8" high text in a quarter scale view will still be 1/8" high if you change the view to half scale.
That's one of the fundamental powers of REVIT.
Mon, Jan 14, 2008 at 1:50:41 PM | How is that a "power of Revit?"
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I mean that question sincerely.  My ADT buddies tell me that when they copy and re-scale a plan, section, whatever, the text, brick texture, dimensions, all are re-scaled as well so they are not too big or too little for the new image.  Why would that ADT attribute be less powerful than the Revit one that makes you have to manually re-do a lot of stuff so the drawing reads correctly?
Wed, Jan 16, 2008 at 11:41:32 AM | Scaling of text, dimensions, and wall textures question.
kesflower
3.5 Stars: 11 Votes
I don't have a problem with that when I duplicate a view, which I assume is what you mean when you say copy a plan.  Callouts also work appropriately.  1/8" text is always 1/8", so no scale factor is needed to print.  As for materials patters, are you using drafting patterns for your cut patterns and modeling patterns for your surfaces?
Ruth Rau
Main Street Architecture, P.C.
adding textures to wall
Tue, Oct 17, 2006 at 9:27:46 PM
Dimensions to Text
Thu, Sep 16, 2004 at 9:17:09 AM
Adding Text Below Dimensions
Sat, Mar 3, 2007 at 10:55:04 AM
11
Rotating the text in dimensions
Tue, Feb 17, 2009 at 12:18:16 PM
Text width for dimensions...
Tue, Aug 7, 2007 at 7:55:42 AM
Page generation time: 2.7016
