Forums >> Revit Building >> Technical Support >> Line Styles and color schemes - transfer between projects
Mon, Jan 14, 2008 at 9:31:04 AM | Line Styles and color schemes - transfer between projects
lbrooksher
(using build 20080101_2345)
Is it possible to save line styles and color schemes so they can be transferred to another project.  We have a large project split into several projects and it would be great if we could easily transfer what we have already set up in the first project.  I know we can set up templates to start a project, but what about when the projects are already built.
Mon, Jan 14, 2008 at 2:58:25 PM | Line Styles and color schemes - transfer between projects
LIZARD2806
3.5 Stars: 7 Votes
You can transfer that information using the "Transfer Project Standards" tool under the file menu.  To use this, open the file you want to transfer the standards FROM.  Then open the file you want to transfer the standards TO.  While in the TO file, go to File, Transfer Project Standards.  A dialogue box will appear asking what standards you would like to transfer, among them are line styles and color fill schemes.
HTH
Tue, Jan 22, 2008 at 10:16:24 AM | Line Styles and color schemes - transfer between projects
lbrooksher
Thank you!  It was a bit tricky as the projects were linked into each other and could not be open at the same time.  We ended up making a copy of the project with the correct lines and color schemes and detached all of the links.  We saved it with a temporary name so we could open it with the projects that it was normally linked to.  Otherwise, your advice was just what we needed.
Color Schemes
Thu, Nov 11, 2010 at 9:30:47 AM
area color schemes
Fri, Jan 27, 2012 at 12:07:13 PM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Color Schemes
Wed, Jun 3, 2015 at 3:15:18 PM
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:05 AM
Page generation time: 0.7074
