Forums >> Revit Building >> Technical Support >> Can I turn off visibility for elements under the toposurface?
Mon, Jan 14, 2008 at 5:18:03 AM | Can I turn off visibility for elements under the toposurface?
Iserhorst
3 Stars: 1 Votes
When I do a section, I would like to be able to turn off the visibility of elements that are under the toposurface.
Does anybody know how this can be done?
Is it a setting I can toggle, or is there some other clever way?
Thanks
Jesper "Revit newcommer"
Mon, Jan 14, 2008 at 1:09:34 PM | Can I turn off visibility for elements under the toposurface?
jonblaze451
1 Stars: 1 Votes
You can actually hide any element in a Revit model without going to visibility settings.  Click on an object(s), right click, and click on hide in view.  You can either choose element or category.  In order to see what you have hidden, just click on the yellow light bulb and the screen will turn pink and show you what is hidden in that view.
how visibility of filter work with the turn on/off of certain category?
Thu, Jan 13, 2011 at 4:03:48 PM
Turn off the same linked elements in every view [ 1 2 ]
Thu, Nov 29, 2012 at 2:51:08 PM
23
Turn off wall visibility on upper floors...
Fri, Mar 4, 2011 at 2:24:23 PM
Visibility elements in a room tag
Mon, Aug 9, 2010 at 2:58:33 PM
linked file visibility
Fri, Aug 23, 2013 at 8:05:11 AM
Page generation time: 0.8407
