Forums >> Revit Building >> Technical Support >> Plan Region not shwoing wall hatch??
Fri, Jan 11, 2008 at 4:19:00 PM | Plan Region not shwoing wall hatch??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I have a plan region in my floor plan to show a high window in the bathroom.  But when I draw the plan region it shows the wall and hatch just fine IN the region.  But the walls that are outside the region lose their hatch and don't show properly.  Does anybody know how to fix this?  Thanks,
Lorne
Denver, CO
Revit Architecture
Mon, Jan 14, 2008 at 11:00:59 AM | Plan Region not shwoing wall hatch??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Anyone?  Please help?
Denver, CO
Revit Architecture
Mon, Jan 14, 2008 at 11:50:59 AM | Plan Region not shwoing wall hatch??
Your description of the problem does not match the image you sent.  The walls seem to hatch correctly on the right.  You may want to look at the wall on the left.
Mon, Jan 14, 2008 at 12:03:29 PM | Plan Region not shwoing wall hatch??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I know that's the problem.  The wall hatch on the right works fine.  The wall on the left gets cut out.  If I drag the plan region all the way to the end of that wall on the left at the corner then I get the wall perpendicular to show up as blank because the plan region is touching it.  I don't understand why it does this half the time?  They're the same height...all those walls in the image.  Refer to both images attached.  All I did was drag the plan region to the full length of the wall.
Denver, CO
Revit Architecture
RA2008 Plan Region Removes Wall Detail Outside of Region [ 1 2 ]
Thu, Sep 18, 2008 at 8:19:25 AM
16
Adjusting the hatch pattern inside of a filled region?
Fri, Dec 5, 2008 at 11:07:40 PM
3-d hatch region
Mon, Aug 11, 2008 at 10:32:33 AM
2d Line Based compnents - rotate hatch region for plan and section
Tue, Jan 31, 2012 at 9:28:27 AM
Plan region not showing lines in detail view [ 1 2 ]
Mon, May 11, 2015 at 11:17:48 AM
15
Page generation time: 0.7507
