13 Users Online (11 Members):
Forums >> Revit Structure >> Technical Support >> Help needed to Align a Filled Region to a "family" (Deck Span Direction)
3 Posts No Rating |
I'm modifying the Span Direction Annotation to look more to our office standards. I've got exactly what I need except the correct visual rotation of the filled region. I tried using regular linework instead of a region, but that created other problems... I need the filled region to rotate with the deck span direction and I'm running out of time on this project. Anybody got a quick fix? I also tried editing the cut fill pattern to "Align with element", but without success. Thanks james
Edited on: Fri, Jan 11, 2008 at 3:41:19 PM
Hey James, Please let me know if this is what were looking for or if I misunderstood you. Brett
3 Posts No Rating |
Yes! But... The deck symbol is running in the wrong direction. We need it turned 90 degrees to match the directino of the deck ribs. Also, I rotated the slab direction (just for the hey of it) on the plans and the symbol went all wonky. Something's still not jiving somewhere... I know this must seem like a silly request but I have a "circular" building where the deck direction changes every 5 degrees and the boss wants it shown properly. I'll have to note every section manually for now. Thanks
Extending Deck Span Direction Symbol |
Mon, Jun 1, 2009 at 12:44:51 PM
"Solid white" filled region that prints in black |
Mon, Aug 1, 2005 at 8:47:27 AM
Detail Component / Filled Region |
Wed, Aug 19, 2009 at 10:57:44 AM
1 1/2" Metal Deck Visibility |
Tue, May 13, 2008 at 11:40:33 PM
Metal decks spanning in different directions on the same level |
Mon, Nov 9, 2009 at 9:10:55 AM
