Forums >> Revit Building >> Technical Support >> Walls not being deleted in all views
Fri, Jan 11, 2008 at 10:53:16 AM | Walls not being deleted in all views
rfinney
I'm using Reivt Architecture 2008. This problem just started yesterday. When I create a wall and then subsequently delete that wall it doesn't delete in all the other view automatically. I have to manually go into 3d view to delete it. Even after I do that though Revit somehow still thinks it there and when I draw a new wall that intersects where the old wall was it creates a break. I went back into some old projects and this problem is happening there also. Any ideas?
Fri, Jan 11, 2008 at 5:05:38 PM | Walls not being deleted in all views
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I know this is going to sound like a dumb question but are you deleting or hiding the wall. The reason I ask is because the default shortcut key for Hide Element is E. If you are typing E to erase then you are just hiding the wall in the current view. To check this click the light bulb icon at the bottom of the screen. If the items are hidden they will show up.
Fri, Jan 11, 2008 at 5:42:09 PM | Walls not being deleted in all views
rfinney
AutoCAD habits obivously die hard with me. I spent the last few months in CAD and I guess I just carried the "E" for erase over without even thinking about it. Thanks for the help, I was about to re-install the program.
Thu, Jul 5, 2012 at 3:52:47 PM | Walls not being deleted in all views
bhawley
THANK YOU SOOOO MUCH FOR HELPING ME FIGURE OUT WHY IN THE HECK I HAD (PROBABLY) HUNDREDS OF HIDDEN OBJECTS!!
I feel pretty darn dumb, but so much better.....
Fri, Jul 6, 2012 at 9:25:22 AM | Walls not being deleted in all views
kepners
Yup I had this exact problem i was just hiding walls. I have changed my UI to solve it.
Views deleted!!
Mon, Apr 11, 2011 at 2:44:15 PM
I accidentally deleted my elevation views.. help please
Sun, Oct 22, 2006 at 8:41:23 AM
Trash Folder for deleted views
Mon, May 14, 2007 at 8:04:31 AM
Views from project/sheet have disappeared
Fri, May 31, 2013 at 11:22:42 AM
Black Walls in 3D Views
Fri, May 11, 2007 at 12:41:31 PM
Page generation time: 0.5023
