26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Wall Section Dims
R-ARC 08 I am dimensioning my exterior wall thicknesses, but I have some trouble when I dimension my curved walls. I have tabbed in order to select the wall faces, but a curved wall seems to be stubborn. Any ideas?
A dimension to a curved wall in section is somewhat impractical. As the dimension constantly changes, you would want a dimension in section to read "varies". At the very least, it should read a dimension, followedd by "varies". If you want to still dimension it the latter way, I would recommend adding a reference plane. When adding the plane, you should be able to grab the end point of the line that represents the top of the wall, then make a vertical reference plane. You can then dimension to the reference plane. HTH
**Using Revit Architecture 2009, 2011, and 2012** |
DIMENSIONS |
Fri, Jan 23, 2004 at 1:58:07 PM
Eq Dims |
Tue, May 1, 2012 at 2:33:20 PM
11
Dims |
Tue, Jul 10, 2012 at 4:41:30 PM
Using 2d group for Wall section, section details called out from wall section? |
Fri, Oct 9, 2015 at 10:50:56 AM
The option to create Wall section not showing up, only building section. |
Wed, Jan 23, 2013 at 3:16:46 PM
