16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Visibility Problem - please help!!!
8 Posts No Rating |
In my project i can't control visibility: in one level, I keep seeing all the levels below. I changed the parameters visibility, however they do not seem to make any diference. This is bad because in an upper level I keep clickint elements that are below. If anyone can help I would apreciate. Thanks in advance.
R-ARC 08? You may need to change your view range. Open the view properties and scroll down to view range and click. You will have the option the set the view level, cutline height, and range of view. You may need to experiment with different numbers until you get what you desire. I hope this will solve your problem.
Hello jcs001, Sounds like Revit has a plan set to under lay. Try going to the floor plans that are showing floors beneath and go into the VIEW PROPERTIES and set the UNDERLAY to none. Let us know if you had already tried this. HTH Brett
The trick to this problem is simple. I would set say Ground Floor LOW (say with cut plane at 1200mm) and duplicate another one with detail and rename it Ground Floor HIGH (with a cut plane at 2500mm). On both plan make sure like brett said, set the UNDERLAY to NONE. With 2 similar Ground Floor plans but diff cut plane I can switch to work on what I want to see and work on.
----------------------------------- G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong. |
visibility problem with linked files |
Thu, Sep 11, 2008 at 11:52:11 AM
Stair visibility issue |
Sat, Jan 5, 2013 at 3:19:19 PM
Problem with visibility |
Mon, Mar 13, 2006 at 9:17:29 AM
Problem witch stair visibility |
Wed, Apr 9, 2014 at 7:08:58 AM
New to revit, overlap visibility problem |
Wed, Sep 4, 2013 at 12:12:23 PM
