Forums >> Revit Building >> Technical Support >> Constraining a Circle
Thu, Jan 10, 2008 at 6:54:42 PM | Constraining a Circle
42willh
Wanted to see if this was possible?
Any advice is much appreciated.
(200Shadey
Fri, Jan 11, 2008 at 12:58:59 AM | Constraining a Circle
dianajohn
Draw your circle then select it, go tp properties & tick the CENTRE MARK VISIBLE box.
You can then align or dimension to the centre mark.
Best of luck.
John A
Fri, Jan 11, 2008 at 6:18:01 AM | Constraining a Circle
42willh
thank you, thank you, thank you!
Wed, Mar 26, 2008 at 3:51:16 PM | Constraining a Circle
NancyHKA
is there any way to change the size of the center marks?
Constraining a circle centered between two reference planes
Fri, Apr 7, 2017 at 8:22:50 AM
Constraining Circle in a family?
Tue, Nov 11, 2008 at 7:27:33 AM
Mass Geometry Flaw | Circle points
Fri, Dec 4, 2015 at 4:04:46 PM
circle resolve
Wed, Apr 7, 2010 at 5:31:01 AM
Structural Column with magic circle
Fri, Jul 9, 2010 at 10:12:58 AM
Page generation time: 0.3666
