Forums >> Revit Systems >> Technical Support >> walls and ceiling are same color
Thu, Jan 10, 2008 at 3:43:28 PM | walls and ceiling are same color
zsigmond2b
When changing the color of the wall material, the ceiling automatically changes to that color as well???
revit arch 2008
 Any suggestions?
K
Thu, Jan 10, 2008 at 3:50:44 PM | walls and ceiling are same color
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Are you using the same material definition for both the ceiling and the walls? If so duplicate the material and apply the new material to one or the other. Also if you have used Join Geometry the material may be automatically applied to both objects.
Sat, Jan 12, 2008 at 7:08:45 AM | walls and ceiling are same color
zsigmond2b
The material definitions were the same.  Thanks for the info!
I wanted to say, this is a really great website and the tech forum has two thumbs up in my opinion.
I haven't seen any program with such great support that revit has online.
Keep on Reviting!
Kristina
Ceiling objects cut by walls
Fri, Nov 20, 2009 at 12:58:09 AM
Revit 2016 How to set the wall height to respond to ceiling heights?
Sun, Apr 24, 2016 at 6:09:20 PM
Ceiling color problems
Tue, Mar 3, 2009 at 12:26:23 PM
Wall and Ceiling Issues
Tue, Jan 20, 2009 at 7:50:47 PM
do walls join differently in ceiling plans for you?
Thu, May 5, 2011 at 11:30:02 AM
12
Page generation time: 1.3575
