Forums >> Revit Building >> Technical Support >> Line Based Template File 9.1
Thu, Jan 10, 2008 at 12:53:57 PM | Line Based Template File 9.1
RWREVITSD
Hey everyone,
I am looking for a "line based" template file to create detail components that is compatible with 9.1. The only one that I can find is for the 2008 version of the program.  Does anyone know where i can Download it from, or is there a workaround for this.
Ryan
Thu, Jan 10, 2008 at 2:07:00 PM | Line Based Template File 9.1
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Here is one
Thu, Jan 10, 2008 at 2:57:53 PM | Line Based Template File 9.1
RWREVITSD
thnk you.
but for some reason when I create a detail component, using that file, and insert into a project i recieve a "fatal error" message and the program has to terminate.....not so good Sad
Thu, Jan 10, 2008 at 3:19:12 PM | Line Based Template File 9.1
RWREVITSD
does anyone have standard detail component template , not line based
Thu, Jan 10, 2008 at 3:47:33 PM | Line Based Template File 9.1
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Not sure why you are getting an error. I tested the template on my computer and it worked fine. Do you have the latest build of the Revit Building 9.1 on your computer. There was supposedly a fix for corrupted template files on that build. Other than that I am not sure. Somebody else might be able to shed some light on the issue. Sorry.
3D line based hosted family template or solution
Sat, May 2, 2009 at 1:46:17 PM
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
Save an existing project file as a template file
Mon, Oct 26, 2009 at 1:11:47 PM
Family Typical Model based on line
Mon, Dec 22, 2008 at 7:55:47 AM
face-based lighting fixture families questions [ 1 2 ]
Fri, Oct 24, 2008 at 12:17:51 PM
15
Page generation time: 7.5098
