19 Users Online (17 Members):
Forums >> Revit Structure >> Technical Support >> parallel door opening in circular wall
19 Posts No Rating |
Dear all, i am hopeing you can help with a problem i have; i have a circular concrete core and i need to place a door opening in the wall; the opening has to be parallel not radial. how can i control the sides of the opening. i have posted a pdf for a better explaination. many thanks
You could use a "door" family that has no geometry drawn on it. Kind of like a cased opening. The opening lines will be straight that way. You could also split your arched wall and trim the corners, then draw another arched wall in the opening with the base offset set at the height of the opening. This is how I typically draw headers.
door opening cutting parallel wall |
Mon, Sep 15, 2008 at 2:54:10 PM
Parallel walls join geometry do not cut opening |
Fri, Jan 31, 2020 at 1:32:48 PM
curve wall in circular opening |
Sat, May 17, 2008 at 3:38:00 PM
Wall opening (door) |
Tue, Mar 31, 2015 at 10:58:12 AM
Circular Arch |
Tue, Jul 21, 2015 at 9:06:15 AM
