Forums >> Revit Building >> Technical Support >> Revit Architecture 08 Parking and Streets
Wed, Jan 9, 2008 at 9:39:26 AM | Revit Architecture 08 Parking and Streets
dlped
Does anyone know how to make parking and streets 6" lower than the site landscape with a curb. My streets and parking slope, but I want to show a curb with them lower than the landscaping.
Wed, Jan 9, 2008 at 9:57:57 AM | Revit Architecture 08 Parking and Streets
If the site is flat, I just do them as a pad with the properties set to asphalt so it renders correctly.  You could also grade the site then do the parking as a slab.
Wed, Jan 9, 2008 at 10:24:42 AM | Revit Architecture 08 Parking and Streets
dlped
My Site, streets and parking are all sloped, so I can't use a slab.  I'm using the split surface tool and changing the topo height to match the curb offset, but then I have a void where the curb would be.
Wed, Jan 9, 2008 at 10:59:55 AM | Revit Architecture 08 Parking and Streets
Curved & sloping curbs are hard to do in REVIT.  Straight and curved curbs that don't change elevation can be modeled as walls.  Straight curbs that change elevation can also be walls with their profiles modeled top and bottom.  For curved walls that change elevation, you may have to do an in place family using solids and voids.
Import full Civil 3D 2012 model in Revit Architecture 2012
Thu, Jan 26, 2012 at 6:23:35 AM
Could Revit allow curb or sidewalk sweeps to be attached to site topo edges?
Wed, Apr 26, 2006 at 4:42:17 PM
What's the best way to make a parking lot
Mon, May 7, 2007 at 2:58:26 PM
Scheduling multiple parking families
Wed, Sep 7, 2011 at 7:50:18 AM
How do you total two things in a parking or any schedule?
Fri, May 29, 2015 at 10:59:58 AM
Page generation time: 1.6388
