Forums >> Revit Building >> Technical Support >> View Templates and V/G Overrides, Revit Linked Files
Wed, Jan 9, 2008 at 8:38:58 AM | View Templates and V/G Overrides, Revit Linked Files
nicolle
4 Stars: 1 Votes
I am trying to create view templates for my drawings and have found that if I have a linked revit file saved in the V/G overrides it uses this same linked view for all of the views that I apply the template too.  For example, if i create the view template with the first floor as the revit link when i go to apply the view template to the second floor, the revit link for the second floor changes to the first floor view.  This would make sense because I am applying a template.  Is there anyway, besides creating different templates for the different floors, to make the proper floor be the link used while still using the same template?  I hope that this makes sense.
Wed, Jan 9, 2008 at 3:09:52 PM | View Templates and V/G Overrides, Revit Linked Files
nicolle
4 Stars: 1 Votes
I figured out that I have to change the default view template instead of applying the view template to the views.  Does anyone know what the difference is and when you should use one vs. the other?
Sat, Jul 9, 2016 at 12:37:06 PM | View Templates and V/G Overrides, Revit Linked Files
minfante14
We use a standard structural plan template that is assigned to the view type.  This template has the Revit links and filters boxes unchecked.  The view template that we create when we achieve our background visibility setting defines ONLY revit links elements, in other words all boxes are unchecked except for the revit links checkbox.  So we APPLY this template and it doesn't affect our structural plan template settings.
I hope this helps.
Marvin L Infante
BIM Technician
Denver Colorado
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides
Tue, Feb 10, 2009 at 2:19:03 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Transfer Project Standards - View Templates
Mon, Aug 29, 2011 at 12:03:03 PM
View templates for Linked Model elements
Sun, Jul 10, 2016 at 9:19:30 AM
2011 linked revit files
Thu, Sep 22, 2011 at 2:52:52 PM
Page generation time: 2.2378
