Forums >> Revit Building >> Technical Support >> Tagging multpile ceiling heights in the same plan
Tue, Jan 8, 2008 at 2:55:08 PM | Tagging multpile ceiling heights in the same plan
Nostromo
I'm working in Revit Architecture 2008.  I have a plan with 2 different ceiling heights and the same ceiling material.  When I tag the ceiling grid in the RCP, instead of reading the Height Offset from Level, it sets all the tags to the same value.  How can I get the tags to read the different values of each ceiling height?
Tue, Jan 8, 2008 at 4:46:30 PM | Tagging multpile ceiling heights in the same plan
You must have done all of your ceilings at the same height.  The tags do work if the ceiling is done correctly.
Ceiling heights in schedules
Thu, May 26, 2005 at 9:26:42 PM
Apartment Groups - Ceiling heights
Mon, Jul 21, 2014 at 11:11:51 AM
Number hatch for ceiling plan
Mon, Dec 17, 2007 at 12:48:09 PM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Ceiling Plan View Range
Sat, Feb 23, 2008 at 9:22:53 PM
Page generation time: 1.6307
