Forums >> Revit Building >> Technical Support >> Hiding Surface Pattern For Specific Wall Material
Tue, Jan 8, 2008 at 2:01:59 PM | Hiding Surface Pattern For Specific Wall Material
twhisker
2.5 Stars: 5 Votes
Here is my dilemma:
I have created soffit walls and ceiling types.  The only way i can make the gyp board wrap in section, elevation, and 3D is to make them the same material.  I also have openings in walls where the ceiling wraps up into the wall.  In order for me to get it to wrap and appear as one, I have to do 3 things:
1) Make both the ceiling and wall the same finish material
2) Set the ceiling or soffit edges 5/8" (thickness of gypsum) inward from the wall edge
3) Join the 2 objects.
The problem is, that wall gypsum doesn't have a surface pattern, so I do not get a surface pattern in my reflected ceiling plan.  I then gave it a pattern and tried to turn it off in elevations and plan, but could only do so for all walls - I do have some brick walls that require the surface pattern.  Anyone know how to selectively hide surface pattern for a specific material in specific views?  Is there a better way to do what i am doing?  Thanks RAC 2008
Revit Architecture 2010
Tue, Jan 8, 2008 at 8:38:13 PM | Hiding Surface Pattern For Specific Wall Material
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can right click any element in any view and "override graphics in view" to turn of the surface pattern or change the display of that element in that view only.
 HTH.
Regards,
Chris.
Wed, Jan 9, 2008 at 12:18:02 PM | Hiding Surface Pattern For Specific Wall Material
twhisker
2.5 Stars: 5 Votes
THANKS!!
When doing that, I saw that I was able to create a filter which would select all my gypsum ceilings and give it a surface pattern for my RCP.
Thu, Feb 21, 2008 at 10:24:52 AM | Hiding Surface Pattern For Specific Wall Material
mcbr138
I seem to recall that in the visibility/graphics overrides dialog box used to contain an entry for floor surface patterns. I can no longer find it in Revit architecture 2008.
Am I looking in the wrong place?
And how exactly should I set floor surface patterns to not display at all, instead of overriding it?
Thu, Feb 21, 2008 at 10:47:29 AM | Hiding Surface Pattern For Specific Wall Material
It's still there in VG -  Under floor , use the pull-down in the pattern column and un-check visible.
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Surface Pattern of Material
Wed, Aug 31, 2005 at 5:25:37 PM
materail surface patterns
Fri, Jun 13, 2008 at 8:06:11 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Page generation time: 1.7869
