25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> My dependant elevation view tag will not show up in my dependant plan view
Hello, I hope i can explain this in a way that makes sense. I have and L shaped building that will not fit on our sheet set-up, therefore, i need to split the plan and elevations up into dependent views. One elevation requiers me to move the crop region to another datum line to fit into the view that it is to be referenced in. The elevation tag and its crop region is well with in the crop region of the dependent view, however, the tag will not show up unless the host elevation is with in the crop region as well. The biggest problem is that i need the title of the elevation on the sheet to reference the plan it is visible in, and since i cannot make the tag show up in the plan i need it to, the elevation title is not referencing the correct drawing. I have made the elevation view independent and it will still not show in the view. I have considered re doing the view with a new elevation tag, but i would rather keep it as part of the overall elevation so that it is eaiser to adjust the line weights. Thank you for any help, i hope you were able to understand the issue. -Mark
Dimension Visability in Dependant View |
Wed, May 28, 2008 at 11:50:35 AM
what are not shared between parent view and dependant view? |
Wed, Dec 1, 2010 at 1:01:47 PM
Problem with duplicating view as a dependant |
Wed, Jun 3, 2009 at 6:53:15 AM
Dependant View Template |
Mon, Jul 7, 2008 at 10:20:12 AM
Girders missing in dependant views |
Mon, Jun 27, 2011 at 12:22:59 PM
