Forums >> Revit Systems >> Technical Support >> curtain wall corner/junction
Tue, Jan 8, 2008 at 7:07:19 AM | curtain wall corner/junction
sidman
I have curtain wall corner I cant get to join!I tried all the methods but I could not resolve. Can anyone tell me how to join the curtain wall at the junctions. Thanks
Tue, Jan 8, 2008 at 8:26:48 AM | curtain wall corner/junction
I usually set both curtain wall not to join and I only put a corner mullion on one wall.
Thu, Jul 17, 2008 at 9:01:40 AM | curtain wall corner/junction
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
I seem to be having a similar problem.
I'm creating my Interior Glazed Openings sheet.
I have the condition in CW 1 attached below. The 5x5 corner mullion is attached to the vertical curtain wall, and that is the elevation I want to show. When I put the mullion in I get the error message in the Warning.jpg.
I can not figure out how to join the curtain walls, and because of this, I assume, I can not get the top and bottom horizontal mullions to go fully across in my elevation. They either go midway on the 5x5 or the 5x5 extends up.
See CW 2 & CW 3
I have tried searching here and the help file but can't seem to find an answer that explains how to join the curtain wall.
As you can see I have no problem with mullion on the south end of the wall.
TIA,
Diane
It's got to be happy hour somewhere
Thu, Jul 17, 2008 at 9:05:38 AM | curtain wall corner/junction
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
Where'd my attachments go??
See if this works...
corner join
Tue, Mar 14, 2006 at 3:52:38 AM
Possible to wrap a curtain wall around an angled corner?
Mon, Aug 23, 2010 at 10:31:11 AM
Curtain wall corner mullion
Mon, May 15, 2017 at 8:33:52 AM
wall intersection with curtain wall
Mon, Apr 14, 2014 at 10:48:38 AM
Curtain Wall Corners
Wed, Mar 1, 2006 at 7:30:18 PM
Page generation time: 1.0272
