9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Solid Fill Pattern
4 Posts No Rating |
Maybe someone can help me - I'm trying to use a Solid Fill Pattern for my New Construction Phase, but can't figure out how to have the walls show up at 60% or 80%, or for that matter anything less than 100% black. Is there a way to have a gray fill pattern? The SOLID fill is not editable, unlike the others. Thanks much.
not sure i understand this question, but filled regions have a lot of options, maybe investigate it further. but it sounds like you might be wanting to control whole aspects of parts of the view. i suggest you look hard at phase filters and their over rides, plus object styles, both globally and by view. help is really helpful - search on these topics and you might find your answer.
4 Posts No Rating |
Thanks for the reply. This question doesn't concern Filled Fegions specifically: regardless of whether it's a Filled Region or a Phase Graphic Override, for any FILL PATTERN the SOLID option is not editable. It comes out solid black. That's a nice option and I use it a lot. However, what I am looking to do is make the fill pattern on the walls be gray, or as AutoCAD puts it 80% Shade (or 20%, or 40%, etc.). So I tried using a regular, editable pattern - like CROSSHATCH - with a tighter spacing of the pattern. Unfortunately this doesn't print, coming out just plain white. It looks like there needs to be a new Pattern created for a Gray SOLID, and I wondered if anyone had anything like that already. Maybe I need to post to the Wishlist forum. Because it's not possible to edit the original SOLID, I wonder if the only way to get it is thru AutoDesk. Thanks again for any help.
4 Posts No Rating |
I had just posted the message above when I turned back to the problem and solved it. I missed something obvious. It's really easy - all i had to do was change the color of the Fill. It is so easy that I am embarrased. Thanks. Hopefully this posting will help others.
so glad you worked it out. i should have suggested the colour option, but i figured you had tried that! revit has depths within depths, and it can be frustrating sometimes. your post will definitely help others.
Solid Drafting fill pattern |
Tue, Jun 23, 2015 at 1:35:01 PM
Lost Solid Fill Pattern |
Wed, Apr 9, 2008 at 7:58:47 AM
Revit 2015 Solid Cut Fill Pattern |
Thu, Sep 22, 2016 at 8:27:54 AM
Solid Fill Hatch |
Sun, Apr 1, 2007 at 8:56:31 PM
Fill Pattern |
Mon, Jun 5, 2006 at 8:13:21 PM
