Forums >> Revit Building >> Technical Support >> Wall footings
Mon, Jan 7, 2008 at 10:08:19 AM | Wall footings
Andrea1983
I am building both the structural and architectural models for our building.  Do to file size I have created two separate files with the structure referenced into the architectural model.  The problem I have is with the footing.  To add a footing it is dependant on the walls above, but the walls are in the architectural model.  What have people been doing about the footings?
Thanks
Mon, Jan 7, 2008 at 10:14:58 AM | Wall footings
JHanby
3.5 Stars: 3 Votes
You can put footing in the architectural model.
Mon, Jan 7, 2008 at 11:35:55 PM | Wall footings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can use the copy/monitor tool that will copy across the walls from the architectural model enabling you to add the footings in the structural model.  The monitor component will update any changes that occur to those walls...
Regards,
Chris.
isolated footings not showing up
Wed, Jul 18, 2012 at 1:17:11 PM
Revit creates two footings at compound wall
Mon, Apr 27, 2015 at 9:22:17 AM
Wall Footings
Mon, Sep 15, 2008 at 4:21:41 PM
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Footings
Mon, Dec 17, 2012 at 1:31:16 PM
Page generation time: 2.5312
