Forums >> Revit Building >> Technical Support >> revit on vista shows only incon and no thumbnail
Sun, Jan 6, 2008 at 10:41:12 PM | revit on vista shows only incon and no thumbnail
cpbc
3.5 Stars: 3 Votes
revit formerly will display thumbnail image for the file open browser on window xp. now that i switch to vista, revit now display only generic icon and no thumbial preview. is there any setting that i can do to make revit display the thumbnail preview? pls help...
best regards,
cpbc
Mon, Jan 7, 2008 at 3:57:33 AM | revit on vista shows only incon and no thumbnail
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds like something went wrong with your install.  I'm using Revit 2008 on Vista Ultimate x64 and in load family mode the thumbnails show fine.  They don't display in windows explorer however...
Regards,
Chris.
Wed, Jan 9, 2008 at 4:29:37 AM | revit on vista shows only incon and no thumbnail
cpbc
3.5 Stars: 3 Votes
thanks. how do i rectify the problem than? should i reinstall? or is there any other way to update registry to include thumbnail?
Wed, Jan 9, 2008 at 1:14:10 PM | revit on vista shows only incon and no thumbnail
LIZARD2806
3.5 Stars: 7 Votes
I don;t thinik this is it, but....  you can try opening windows explorer, go into whichever folder the folders are in (your c: drive, for example) and then  click organize, choose folder and search options, go to the view tab and make sure that the option for "always show icon, never thumbnail" is not checked.
Mon, Jan 21, 2008 at 1:19:41 AM | revit on vista shows only incon and no thumbnail
cpbc
3.5 Stars: 3 Votes
thanks. however, the option for "always show icon, never thumbnail" is not checked. i am now running vista business 32 bit. by the way, the jepg and avi file shows up thumbnail just fine. i haver tried re-installation but it does not help.
best regards,
cpbc
Wed, Feb 27, 2008 at 7:37:50 AM | revit on vista shows only incon and no thumbnail
Dafpfy
3.5 Stars: 11 Votes
I have the same problem , did you find how to fix this yet?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Sun, May 3, 2009 at 7:59:49 PM | revit on vista shows only incon and no thumbnail
YouiGetWhatYouGive
I am having the same problem. does anyone know how to fix it?
Wed, Nov 4, 2009 at 4:20:32 AM | revit on vista shows only incon and no thumbnail
davidpunie
If thumbnails of projects etc do not appaer when browsing but only a big R-icon shows, you could try the following
Run the command window in the Administrator mode (under Windows Start type "cmd", right-click on the result and choose "Run as Administrator"Winking.In the command line then type:regsvr32 "c:\program files\revit architecture 2009\program\revitpreview.dll"A message confirming a successfull registration of the DLL module should appear
for us this seems to help in most cases,
any feedback is welcome
David
Mon, Jan 25, 2010 at 12:04:01 PM | davidpunie
EvgenyK
Quoting davidpunie from 2009-11-04 04:20:32
David,
Thank you for the idea, but it doesn't work for me. Sorry. May be it happands because I use Vista x64?
REGARDS,
EK.
How thumbnail view is created in revit
Tue, Jan 8, 2008 at 7:23:19 AM
Revit files that cannot be deleted in vista
Tue, Mar 24, 2009 at 3:33:39 PM
Thumbnail preview for NESTED Revit Families
Tue, May 14, 2013 at 5:18:20 AM
Setting Family thumbnail orientation in PROJECT (After loading the Family).
Wed, Aug 8, 2018 at 11:05:44 AM
HP DESIGN JET 1050C FOR VISTA 64 BIT
Fri, Apr 18, 2008 at 6:39:35 PM
Page generation time: 1.3204
