Forums >> Revit Building >> Technical Support >> newbie - needing help with grids
Sat, Jan 5, 2008 at 9:55:04 AM | newbie - needing help with grids
kunal1983
hi,
i have a problem with my grids, my building has a undergroung car park with is on a different grid, (eg 6x6 and levels 0 to 4 are on 5x5), i places the grid in the basement car park, but the grid appears on all levels, so i hide the element on the other level, but now when i place another grid line on my ground floor it doesnt appear, and only appears on the basement floors, how do i get around the problem?
thanks
kunal
Sun, Jan 6, 2008 at 12:34:29 PM | newbie - needing help with grids
kunal1983
hi
i found the problem, its bcoz i have hide the elements on the plan view Cryingthe grid lines), so how do i un hide the elements on that plan?
thanks
Sun, Jan 6, 2008 at 3:08:02 PM | newbie - needing help with grids
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds like you need to read up a little more on your datums (check this in the help files as there is some useful information there).
Grids have a 3D and 2D extents.  What you essentially need to do is set the 3D extents of you basement grids to only go as high as the next level and conversely with the grids for the rest of the building.  You'll need to do this in an elevation or section.  When you select any datum line (level, grid, reference plane...) the solid dot at its end point is its 2D extents, that only effects the view you are working in if you change it.  The non-filled dot represents the 3D extents of the datum line.
 Occassionally (but not always) you will also get some blue text appear that says other 2D or 3D depending on what mode the datum is currently in.  Click it to toggle between the two.
 By right clicking on a datum you can also do things like maximise its extents, drag extents etc...
 On the level directly above the basement you probably won't be able to avoid having both sets of grids display (unless you start using scope boxes, which may confuse you more) so its best to use your reveal hidden elements and right click "hide in view" function to get the appropriate grids to display.
HTH.
Regards,
Chris.
Newbie needing advice
Sat, Sep 29, 2007 at 4:53:35 PM
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
I'm a newbie....am I missing something?
Tue, May 6, 2008 at 2:54:12 PM
multiple scope box for grids
Tue, Sep 1, 2015 at 8:35:46 AM
Page generation time: 0.0670
