19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> corner windows
25 Posts No Rating |
hi.. again..
im trying to do a corner window and have spent almost a day trying to get it rite. i tried to use a window and put it in the corner and overlapped another window with it so both their mullions are at the corner. but i still see a little piece of wall. how can i get a clean and realistic corner window?
thanx
Checkout my fixed gl@ss corner window in the family explorer i uploaded a while back. Can't remember if its the latest incarnation but you can adjust for various corner angles, wall thicknesses and also adjust frame thickness and leg lengths.
Trust this is helpful. If you can't find it let me know.
THANX.. it helps... but is this the only way to do it? cuz mostly i have 90deg angles..
Well no its not the only way of doing it, but the advantage of this window is that its one family for instances and a simply matter of changing the type in the project and setting it to 90º...
thanx the corner window helped... but i have a question if im using curtain walls which are embedded into the wall how can i clean up the corners so that the wall doesnt show? what if its frameless glcurseand i dont wanna put a mullion on the corner?
Mr. Spot-- How do you go about altering the wall to make it a 90 deg. opening. I am able to change the window itself, but not the wall. Thanks. ac
Corner windows with variable angle |
Tue, Dec 27, 2016 at 4:47:10 PM
Corner windows |
Thu, Apr 10, 2008 at 9:14:45 AM
Corner Windows |
Fri, Sep 11, 2015 at 11:03:10 AM
Corner Windows |
Sun, Feb 25, 2018 at 6:27:00 AM
Corner windows |
Tue, Aug 2, 2005 at 1:51:34 PM
