Forums >> Revit Building >> Technical Support >> brick sill below window on brick wall
Thu, Jan 3, 2008 at 4:56:27 PM | brick sill below window on brick wall
BRIANDHADLEY
1 Stars: 1 Votes
How is the easiest way to create a window family with an angled brick sill.  I created one with an extrusion but i dont know how to make the sloped opening in the brick part of the wall.
Fri, Jan 4, 2008 at 3:31:25 AM | brick sill below window on brick wall
geofm
Brian , i have been struggling with this area also.
see attached rfa file that has an example of what you are after.
hth
geoffm
Edited on: Fri, Jan 4, 2008 at 3:40:52 AM
Edited on: Fri, Jan 4, 2008 at 6:08:27 AM
Fri, Jan 4, 2008 at 10:00:35 AM | brick sill below window on brick wall
BRIANDHADLEY
1 Stars: 1 Votes
That is what I'm trying to create.  How do you make the opening?
Sat, Jan 5, 2008 at 6:43:37 AM | brick sill below window on brick wall
geofm
i think i have it sorted.  open window family for editing, turn on wall in view props. cut a section through the window. hilight cut opening(click on wall, tab till cut opening is displayed), click on edit and alter to suit required sill position ( eg 172 mm below frame) and save. u need to fill in behind with a solid extrusion to say the inner leaf thickness(for b/v) which allows space for your solid extruded sill bricks.
i tried it on another window family which had a cut extrusion rather than a cut opening around the window frame. the cut extrusion was easier to edit . ( didnt need to fill in behind.)
in both cases the section was handy.
 cheers
geoffm
Thu, Mar 13, 2008 at 6:10:23 PM | brick sill below window on brick wall
twhisker
2.5 Stars: 5 Votes
I am trying to do the same thing.  I have a brick wall (thin brick - "stick on" 1/2" thick actually) with a slopd brick sill under the window.  When I use a wall sweep with the sill profile I created, it cuts the wall only where the face of the sill intersects the wall.  I then have a piece of the wall reamianing from the top of the sill to the bottom of the window.  I would think that there would be a way to increase the size of the cut above the sweep.
I have tried to modify the opening and add an additonal opening.  That works, but I have a huge hole under the window on the interior side of the wall.  I tried to use a void as in the example above, but cannot get the proper angle set.  (I want to still use a sweep for the sill seperate from the window).
This is a basic construction method, you would think Revit shoiuld be abole to handle it.  Any ideas??
Thanks.
Revit Architecture 2010
Window in brick/stud wall
Fri, May 26, 2006 at 2:43:48 AM
Sloped interior window sill in wall
Tue, Feb 14, 2012 at 3:30:26 PM
Rowlock brick Sill
Sat, Mar 17, 2012 at 8:01:34 AM
12
SLOPING CAST STONE WINDOW SILL APPLICATION
Thu, Feb 28, 2013 at 8:38:42 AM
Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
Tue, Jul 24, 2012 at 5:31:29 AM
Page generation time: 0.8789
