Forums >> Revit Building >> Technical Support >> Putting Topography Info in a REVIT drawing
Tue, Mar 1, 2005 at 5:03:50 PM | Putting Topography Info in a REVIT drawing
rapscallionyouth
Does anyone know of a good source that instructs how to put or creat topo on a REVIT drawing? please help it would be greatly appreciated! Raps
got a gun in fact i got two thats ok, man cause I love God
Tue, Mar 1, 2005 at 5:35:02 PM | RE: Putting Topography Info in a REVIT drawing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you have a survey drawing where the contours are drawn as polylines with the correct elevational properties then its very simple. Just a matter of importing the survey plan at the correct scale as a model element. Then select topography-->use imported-->select the import dwg file and select the appropriate layer for the contours... Then its done... If there are any odd points you can fix these individually by selecting the point and adjusting its height. You can then remove unwanted sections of the topography by using the split surface tool in the site tools progressively... Remember you cannot split a surface into more than two pieces at once. Then simply delete the unwanted selectiong of the topography... HTH.
Wed, Mar 2, 2005 at 2:53:03 PM | RE: Putting Topography Info in a REVIT drawing
rapscallionyouth
so...its this simple i can go out and survey an empty lot download the points on Land Desktop...create the contours from the shots then just import it into REVIT? of course...correct scale as model element select appropriate layer and all that i dont know anything about splitting surfaces and using most of the site tools but with experimentation...it is that easy anything else you think i should know? thanks for the help! Post edited on 2005-03-02 14:53:41
Wed, Mar 2, 2005 at 5:31:56 PM | RE: Putting Topography Info in a REVIT drawing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes you can also bypcursethe the land desktop step and simply put the points straight into revit... In a site plan, just insert points by setting the appropriate elevation and start entering all your spot levels... Split surface is really a matter of drawing a boundary where you want to cut the site. The sketch doesn't have to be closed, just has to split the site into no more than 2 pieces... you can then use subregions to define different materials to different parts of the site.
Wed, Mar 2, 2005 at 8:28:37 PM | RE: Putting Topography Info in a REVIT drawing
ale02
ale02 Avatar
3 Stars: 3 Votes
Quoting Mr Spot - 2005-03-02 17:31:56
"Yes you can also bypcursethe the land desktop step and simply put the points straight into revit..."
You mean just the points (with proper elevations info) straight to revit and revit can figure out the contour?!
never did that before with land desktop..Always thought we have to define the contour line in ACAD than only import to Revit... Thanks for the tips
Post edited on 2005-06-13 03:23:29
Life is never easy but nor it should be complex. Just stay simple Smile
Sun, May 1, 2005 at 5:43:16 PM | RE: Putting Topography Info in a REVIT drawing
MongooseST3
HTH.You stated " Just a matter of importing the survey plan at the correct scale as a model element. Then select topography-->use imported-->select the import dwg file and select the appropriate layer for the contours..."
Is this the Toposurface command in Revit? If so when I import do I importing using the pulldown menu under FILE? When you say select the apporpriate layer, what do you mean. It appears that the contours and DWG come in in the IMPORT command as one block where one needs to put individual points on the contours ( Which is too laborous) so how can I get my ACAD dwg with my contours already preset at their respective elevations into revit where I can start to work the site??
Thanks
Mon, May 2, 2005 at 12:49:19 AM | RE: Putting Topography Info in a REVIT drawing
Arnel Aguel
[Quote from above ]
Open your site plan then import your dwg file it will appear in your site plan as one block then click toposurface after which the design tab will show the option use imported click that icon then click your imported topo in your site plan revit then create a topo points based on your contour lines.
Post edited on 2005-05-02 00:51:01
Mon, May 2, 2005 at 5:52:25 AM | RE: Putting Topography Info in a REVIT drawing
Rookwood
Spend 30 minutes with the Tutorial you can find inside Revit's Help Menu. It is well written and has illustrations for easier understanding. It will explain/illustrate both methods mentioned above.
adding topography not to scale
Sun, Mar 5, 2006 at 10:28:45 PM
A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
Tue, Nov 22, 2011 at 6:07:37 AM
View linked CAD file on top of Topography
Mon, Nov 19, 2012 at 10:52:16 PM
Delete "stock" Project Info. & Drawing Sheet Parameters?
Mon, Nov 23, 2009 at 4:05:40 PM
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:01:59 PM
Page generation time: 4.3229
