Forums >> Revit Building >> Technical Support >> Ceramic Tile Flooring
Sun, Dec 30, 2007 at 11:38:37 PM | Ceramic Tile Flooring
rcobbjr
3.5 Stars: 3 Votes
I am trying to create a 6" x 6" and 12" x 12" ceramic tile flooring. I want the tile flooring to appear as tile in the model when I do the interior rendering. How do I create the flooring to show up accurately in the model? I also want the tile pattern to show up in the floorplans with the proper pattern. How do I do that?
Wed, Jan 2, 2008 at 9:03:02 AM | Ceramic Tile Flooring
GunawanArthur
4 Stars: 4 Votes
You can use real ceramics model, create a ceramics model family, and really create all the ceramics tile as floor model or generic model. But it will take more time and more system resources.
My faster method to do this is
you can simply maps the material to the floor when you need to render them, and adjust them as necesarry. And use model line pattern to make it appear on all of your work drawing, the layout plan, section or elevation (for bathroom ceramics, or other tiling material on the wall).
 hope it helps..
Revit Architecture 2011
Partial height Ceramic Tile
Thu, Feb 23, 2012 at 9:31:28 AM
Can Door/Window cut through multiple walls
Wed, May 26, 2010 at 10:06:37 AM
Flooring Tile setting out
Tue, Jun 18, 2013 at 3:59:02 AM
Visibility Graphincs
Wed, Sep 19, 2012 at 8:51:15 AM
Flooring
Wed, Jun 15, 2005 at 11:22:52 AM
Page generation time: 1.3892
